97 7.3 no start
97 7.3 no start
I have a 97 7.3 powerstroke.
Truck was running, lost two injectors unplugged the bad injectors, truck still ran missing 2 injectors. I bought new injector from SwampDiesel, Got Injectors installed everything back together. Truck will not start, Truck tries start, but no smoke coming out tail pipe. I get no codes from the computer either. I have checked and rechecked connections. I find no fuses blown out. I have oil pressure and fuel in the bowl. Help Please
[QUOTE=Woodsgirl;17062607]I have a 97 7.3 powerstroke.
Truck was running, lost two injectors unplugged the bad injectors, truck still ran missing 2 injectors. I bought new injector from SwampDiesel, Got Injectors installed everything back together. Truck will not start, Truck tries start, but no smoke coming out tail pipe. I get no codes from the computer either. I have checked and rechecked connections. I find no fuses blown out. I have oil pressure and fuel in the bowl. I have been cranking engine about 40 seconds on 40 seconds off. I have burned up one starter. HELP PLEASE
download and print this no start flow chart
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
I have replaced camshaft sensor and fuel pump under the fuel bowl. I have checked fuses underhood and dash, I get no codes or any edidit lights to come on. The truck turns over but no start and no white or black smoke out tail pipe. I have also burned up two starters. Help, appreciate all the help
I know you want to just crank and crank and crank and hope it fires up but clearly that's not working.
Check everything you touched. Make sure all the sensors are plugged in. Check the IPR sensor right near the fuel bowl. Make sure you didn't accidentally bump it with something and break it.
LI John M
16
08-13-2016 09:12 AM
joker67735
09-12-2013 09:28 AM
