Ignition switch
Old 03-25-2017, 07:35 AM
STEVE1103's Avatar
STEVE1103
STEVE1103 is offline
Ignition switch
How do you wire a starter button to an ignition switch, like my 53 Merc had? Need to wire my fuel gauge too.
Old 03-25-2017, 08:01 AM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,660 Likes on 1,342 Posts
You want a keyswitch and a pushbutton also? You already have a keyswitch with the start function? What year/model/engine are you working on? Do you have wiring there now or no wiring?
Old 03-25-2017, 04:49 PM
STEVE1103's Avatar
STEVE1103
Have a new ignition swicth without the start function. No old wiring, have all new, E- Zee wiring harness, does have stencils all the way.
Old 03-25-2017, 05:27 PM
Franklin2's Avatar
Franklin2
Most start buttons are just momentary pushbuttons wired to a hot wire on one side, and running out to the starter solenoid on the other side. Push the button and it sends power to the starter solenoid. The motor turns over, but won't start unless you turn the other keyswitch also. And you can wire a neutral safety inline with this wire to the starter. If you have a automatic and live in a place like I do where we have inspections, they check such things as not cranking over unless it's in park or neutral.
The fuel gauge depends on what gauge you are using, and what sending unit you are using.
Old 03-25-2017, 06:07 PM
STEVE1103's Avatar
STEVE1103
Going to try and use old gauge in the cluster (55 F 100), put a 66 Mustang gas tank in with the sending unit, think they might be OK together.
Old 03-26-2017, 01:19 PM
Franklin2's Avatar
Franklin2
The 55 was 6 v positive ground, the mustang will be 12v negative ground.
I had a 53 Ford f100, don't think the original sender is going to work for you. If you take it apart and look at it, it actually is a glorified turnsignal flasher. It actually grounded and ungrounded the old gauge continuously like a flasher. The sending unit arm mechanically presses on this flasher unit, making it flash faster or slower. So this grounded and ungrounded the ground for the fuel gauge faster or slower, which made the gauge read higher or lower.
The mustang unit has a variable resistance like most modern sending units do.
What I did was kept the original tank. One good thing about the original tank, it had two separate holes, one to pick up the fuel and the other for the sending unit. You will find most modern tanks like the mustang have one hole for both fuel pickup and the sending unit.
When you have a separate hole for the sending unit, you can get a fuel gauge setup from the aftermarket. I got one from JCWhitney, mounted the guage under the dash and made a adapter and mounted the sending unit in the tank. It worked but the gauge was cheap and would stick. If I had spent more money I would have had more success with it.
the gruffalo
01-08-2022 07:38 PM
turnrjr
08-17-2019 04:42 PM
pokermonwsu
23
05-05-2014 02:40 PM
joshofalltrades
06-16-2013 12:52 AM
Woodsman_30350
06-06-2011 12:27 PM
Quick Reply: Ignition switch
