hey guys,
im wondering if the doughnut gasket is a must? i welded new flared ends on my the existing pipe, and it seems to be a tight fit. Will it sound like garbage if i skip it?
If it lines up/tightens down and does not leak, you should be good to go. If it is miss a lined or leaks, try a thin layer of high temp RTV on the mating faces or yes then a doughnut.
