intermittent crank no start (no pcm connection)
this has happened only 4 times in the last 4 years till about a month ago. (happened twice in 2 days)
with key on i get the glow plug light and CEL on but no power to the pump (FASS) and obviously no fuel pressure. it will crank, but nothing on the tach.
I've tried plugging in a scanner and it doesn't make a connection with the pcm. all lights work and gauges work (tach and speedo are at zero obviously)
before i couldn't pin down when it happened due to being so intermittent. but the last two times it has happened it was when i started it and drove somewhere close before it was at full operating temp. (and in retrospect the previous times was a similar situation).
she'll start fine cold, and when at operating temp.
when it happens i pull the batt cables let it set. reconnect and within a few tries works fine.
any ideas? pcm going bad? is there a sensor i need to check?
new motor has about 25k on it.
thanks.
thanks.
jhl3
18
03-03-2016 10:58 AM
freerider15
11-27-2015 02:17 AM
