wheel and tire size for fatman ifs
I have not had good luck using someone elses BS measurments. For what you spent on that IFS I would suggest you get it set at ride hieght with the brakes and tire size you wish to use and measure yourself. That way you can test clearance and stance prior to ordering expensive wheels. HIO was just suggesting you start with the manufacture who should have no problem giving you a good conservitive starting point.
I used a measuring tool to mount a tire for mine like this.
I have a Mii up front. I have 20x8 with, I think, 4.5 inch back space. I will have to find my paperwork. 235/55/20 tire which is about 30 inches tall I recommend you roll the fender lips if you plan on running a wide tire in front. Especially if you plan on using dropped spindles. Backspace is very importand if you are going to run a Mii because it gets the truck really low. I would try and get the wheels as centered (neutral) in the wheel well as possible or you will have rubbing problems.
devil driver
03-20-2011 01:07 AM
1965_ford_mustang
03-17-2002 08:47 PM
