if you have a oil pan gasket, that's your issue, RTV only.
also oil can leak through the keyway on the crank snout.
if it was the balancer seal, it would sling oil all over the place.
It could be leaking at the fuel pump to block gasket as well. That one is quick and easy to clean up and reseal. Regardless of whether you suspect the front leak is the oil pan or fornt seal, the front cover must be removed so if the leak is bad enough to warrant fixing, just pull the cover and do the front seal and reseal the cover.
