Water Pump Wear Pattern
I am in the process of replacing my water pump. After I removed the pump, I found quite a bit of metal-on-metal wear between the impeller and the water pump housing. Yikes!
Is this common?
I've been running a coolant filter on my system for years now, so hopefully its been effective at collecting some of the metal that has clearly been worn away. Either that, or this is a sign that the filter isn't working at all!
I'm a little worried that the new pump will scrape the scars left from the old pump. Any suggestions?
Is this common?
Interesting that you posted this. I just had a truck that had 458,000 mi and was checking the engine out. The timing cover had the same issue, but the impeller had no wear marks so it had been changed at some point. Given that this truck was not really worth much anymore, the pump was changed but nothing done with the gouged timing cover. It seems like the impellers come loose, gouge the cover and let you know with the truck then overheating.
Depending on how much work you want to do, you could change the cover but that requires pulling the engine. Given that there is no pitting of the cover, if the new impeller does not drag on the cover, I would run it personally. If you are super paranoid a timing cover change could be done, but on mine since it is an around town pickup instead of a long hauler I left it alone.
Oh, I would also flush according to Gooch's procedure since your filtration was bypass. Don't want any metal shavings to end up ruining the new water pump seal!
Additionally, no. I have only heard of this on two trucks and have changed many 7.3 water pumps. The impeller on the new pump should not rub the timing cover, and when the water pump bolts are torqued correctly, the oring will crush fully and the mating surfaces on the pump will touch the timing cover. In other words, there is no way to control the depth of the impeller other than how far it is pressed onto the shaft and bearing play/clearance.
Thanks for the feedback.
The truck didn't present extreme symptoms before I decided to change out the pump. There was a squeaky belt sound and some a very slow coolant leak from what looked like the weep hole. The truck never overheated and I didn't ever hear any grinding or other nastiness.
I believe that the pump is the original.
The truck has 199.5k miles on it. I've had it for the past 120k or so of those. This is the first time that I've changed the pump. I've had the filter in the mix for about 80k of those miles.
I'm replacing with an OEM Navistar pump from Clay at Riffraff.
That was a good call on the flush -- Thank you. I got a lot of junk out of there. Each successive bucket-full had less and less sediment in the bottom. The final couple of buckets looked really clean; I am pretty confident that it is about as good as I could make it.
I put in a fresh batch of CAT EC-1, distilled water, and a new coolant filter so hopefully it'll be good again for a while.
old farm truck
2009 - 2014 F150
02-26-2020 02:06 PM
carnut122
27
04-14-2017 07:11 AM
bluegoose95401
27
06-06-2015 10:54 PM
MustangMatt96GT
01-19-2009 10:22 PM
