Shaking sputtering and loud rattling sound
2005 ford expedition 150,000
So the truck has been intermittently running rough the past couple of weeks. It was running fine cold and once warmed up it started making a hell of a racket under the hood. It would intermittently hesitate and shake upon acceleration and finally the check engine light came on the other day. Here are the codes below and all indicate (bank 2),
p0345
p0349
p0221
I took a shot and changed out the camshaft sensors. It ran great and quieter than ever for the first 10 minutes and once warmed up, the problem still exists. I had the battery disconnected while changing the sensors and checked with the scanner upon starting if they still showed up but were cleared already. I changed the vct solenoids last year. Im kinda lost as to where to check next. Any suggestions?
Thank you
p0345
p0349
p0221
Thank you
The chance of both the CPS and the TPS going bad at the same time is quite unrealistic. I'm more inclined to think you have an issue with the wiring at a place that's common to both circuits. By common I don't mean there's a common electrical point in the wiring because there isn't. I mean a place where both run near each other and might be damaged.
I reset the computer prior to the video. Since then and only a few miles, the P0345 code is the only one to come back.
Yeah, on passenger side there's three large connectors on a flat aluminum box, that's the PCM. One connector is the body harness connector, the next is the engine harness connector, the third is the transmission harness connector. I believe the smaller one is the transmission, and the two of the same size is the body and engine. Just try to follow where the harness go, the one that leads to the engine is the engine harness connector. Disconnect it by pulling the plastic bar on top, don't exert too much force on it or you might snap it. just pull it gently out. Inspect the pins and all to see if it's clean, no bent pins or anything. Could even spray some contact cleaner in there, then reseat the connector. I might even personally consider using dielectric grease or contact grease just to help prevent moisture from getting in there.
Thanks for all of the help!
Not sure if this will help as i'm not anything close to mechanically inclined--but I will say that on my 06 expy i had a similar problem. All would run fine while cold but once it warmed up it would run rough at low rpms. Especially at a stop sign the engine would start to shake until i got it up to higher speeds again. A couple of times it would stall at stops/low speeds. The engine shaking got pretty severe at times. I changed both vct solenoids and now there is no problem at all... well i do believe one of my camshaft locking pins is loose because i can hear it rattle at low tip-in acceleration once it's warmed up.. but no more violent engine shaking--no more stalling--runs good. I believe I had the same codes you have. I see that you changed the solenoids last year--did you use motorcraft?
So i think the problem has been pin pointed. I tore into the repaired wires and while all looked ok, i rewired it again and the problem seems to be resolved. Those damaged wires are actually running to the mass air sensor. However, im not very happy with the wiring job once again. The problem is, there is no wire left before it travels through the big loom that carries all the injector, coil etc wires along side the fuel rail and its not an easy spot to work. The squirrel chewed about an inch away from that point and so now with the 2nd repair i was working with even less wire. From here on out, its either open up that wire loom alongside the fuel rail (which could introduce a host of new problems) to expose more wire or order a new engine wire harness all together and be done with it. I already need a new mass air sensor harness because the clip broke (I have it rigged temporarily).
It shouldn't be that difficult (with the PS reservoir moved and intake tube removed) to change out the whole harness right?
I have 2 vans with the 2v 5.4's and they are so quiet and such a pleasure to drive. These 3v's are so annoying with the cam phaser issue. Im sick of people suggesting that i have a lower end knock in the motor. I tell them is the cam phasers and they just look at me dumb founded.
Yes I only use motorcraft when it comes to electrical sensors / solenoids.
Thank you
Not so difficult to replace the harness, but it's cramped in the back there. Would be easier if you removed the intake, but that's a bit much.. hehe.. You're gonna have to remove the throttlebody though, but that's fairly easy.
You could just order a pigtail for the MAF sensor though, the red clip on mine is broken as well, but the other clip is still there so I haven't bothered with it yet...
Watch out for those darn squirrels now!!
That's why I go and buy those 5lb. jumbo bags of peanuts and toss them in the yard every so often in the winter. The animals have trouble finding food so they go after the wiring. Every since I started tossing out the peanuts they haven't once touched any wiring. I probably spend about $30 a year on the peanuts but to me it's money well spent. My wiring stays intact and I score points with the animal kingdom.
Restlesswildman
09-25-2014 05:19 PM
Towerjack
11-06-2007 04:02 PM
bugsquatslow
03-21-2007 11:02 PM
westladog
13
12-17-2006 02:19 PM
