Where can i find
Read through this and see if you see it. If it's the diaphragm you may be looking at new hubs.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Autolock Hub Ring Clips (2) and o-rings (2) For the Ford 7.3 Diesel Front Hubs
I am pretty sure the auto lock and manual hubs use the same outer 0-ring and retaining ring.
This o-ring is not gong to make your hub turn freely though. You need to clean out and lube the dial. Take a look at guzzles write up on the procedure, it if for auto lock hubs so yours will be much easier and straight forward and a lot less parts. To disassemble the hub is one retaking ring and one snap ring.
I just did mine (manual hubs) Saturday because my wife has been using my truck and I hadn't realized how stiff they had become. They turn like a hot knife through warm butter now.
Its the " dial" seal that I'm looking for.
When I took it apart it was stuck, and seal came out in pieces on both of them.
Mark, do you know the PN of those seals?
Most O-rings are A 568-XX. I do not believe the original seal were O-rings.
But an O-ring should work. Water had gotten into one of my hubs. It was not to bad, but it's been pretty dam dry in California the last few years.
The outer O-ring is easy to find.
Thanks
Thanks
I do not know any part numbers. I am blessed with several outlets for O-rings in my area and I just go in with the old O-ring and/or the part and get fitted up. When heat is involved it is essential to get Viton. Otherwise, as in this case, Butyl is acceptable. ACE hardware would probably have something that would work here.
I think you're gonna find that is The diaphragm in the end cap, and it is not field replaceable, they don't sell the part. And dorman doesn't even sell one. Time to buy a replacement auto hub....Dorman DOES sell one of those....
__________________________________________________ ______________________
Now that's what I call planned obsolescence.
