Remote starter help
Look at the list of 10 connections and think.
What you are doing is paralleling the truck's ignition switch so the remote module can perform the same as if you were in the truck operating the ignition switch from Run to Crank and back to Run again.
For example pins 2, 6 and 7 deal with the starter so the motor can be cranked.
Pins 3,4,5 power the ignition and fuel injection etc.
It's just following the requirements for the PCM to be powered up, power to the coils and fuel injectors and the cranking/release function.
You really need to have a good understanding of this because when/if there is a future issue you have some idea what function to check out.
Good luck.
Good luck.
