68 Exhaust
Summit Racing carries Flow Masters Dual Kit that supplies a variety of pre bent tubes that you could use to put together your own system.
https://www.summitracing.com/oh/part...5936/overview/
Might work for you since you could exhaust clamp it together and add hangers as needed.
cstoyer
cstoyer
I know Dodge does factory exhaust out the back but YEARS ago I heard the reason why Ford Never has. Dodge does it for those fancy cut outs in the bumper. Sales gimmick. Ford doesn't because of Turbulence. The same turbulence that Nascar drivers use when they are drafting. This turbulence "can" hurt exhaust flow in some situations. The air flow around and under the vehicle can help "pull" the exhaust out on side and under exhaust systems.
hodges710
04-25-2011 07:19 AM
