4.10 or 3.55?
Received 6,657 Likes
on
General consensus seems to be that 3.55 is just right for the diesel. I would have to go through the build process to confirm this but I'm not sure the 4.10 is available for the diesel. I have the 3.55 on mine and it took some configuring to get it. I had to get the camper package which I was OK with since I wanted the sway bar anyhow.
Or maybe go with the F450 since it's "only 4.30" option is about the only negative I can find (if you really want the 3.55 -- which in this case I don't believe you do). Since your application is best suited for the 4.10 (or lower than the 3.55 anyway) -- if it were me I'd consider the F450. The F450's larger brakes and tighter turning radius may be of interest, and IMHO looks the coolest.
Edited and corrected (thanks Rodney).
Or maybe go with the F450 since it's "only 4.10" option is about the only negative I can find (if you really want the 3.55). Since your application is best suited for the 4.10 -- if it were me I'd go F450. The F450's larger brakes and tighter turning radius may be of interest, and IMHO looks the coolest.
I've got a work truck F450 w the 410s, it's awesome upto and incl the rural roads, but if you do a lot of super highway speeds, go with the 355. The 410 is a winding hi RIPS monster when up in the 70+mph range, also our mileage sucks on the 450 doing these speeds as well. We have discussed this on other threads as well, it's opinionated of course, but I believe it comes down to what you will be towing and at what speeds.
925ft/lb TQ will hoist even your 21K 5er up hills passing gassers like they're standing still, and remember, you can always lockout or drop a gear as well climbing (if your autoT/TowMode doesn't do this as you see fit).
Good luck
Good luck
