Narrow wheel and wide tire issues
I see quite a few people sticking 12.5" wide tires on the stock 8" wheels and question if any significant issues exist putting a wider tire than recommended on a narrow wheel? I found a set of wheels and tires that I wanted at discount tire but the first set (toyo RT 35x12.5) did not have a high enough load index for them to sell them for the application. Then I thought I found the Nitto ridge grapplers (same size) that worked but they were 125 LI when a 126 is required. So after the back and forth they were willing to sell the 35x13.5x20 ridge grappler tire to me for the 20x9 wheel without issues. The problem is that I now see the tire minimum reccommended wheel is 9.5" which brings up the question of what issues this may cause if any??? I'm fine with the wider width but I don't want worse handling or ridge quality if it pertains.
on
The 20 inch wheels are actually 8.5 inches and fit within the requirements for the 12.5 tires. The 37/12.50/20 tires I have on have a 3,750 load rating. I can only guess that if wider tires are installed than the wheel is designed for that they will wear faster in the middle at max pressure.
Epic....I could be wrong...but aren't all the Ford 20's 20 x 8...not 8.5??
on
The stock wheels are 20x8 according to the literature published on the subject...Epic, did you measure them when building up your new setup? Wouldn't surprise me if the docs are wrong.
OP, I faced the same issue...and early next week have the following going on:
- Toyo AT2 Xtreme - 325/60r20 (35.5"x13")
- Fuel Boost 20x9 +1 offset
These run at 65psi, so I'll drop that in Forescan, unless the tire shop will do it for me. Feels like a great compromise in size, aggressive good looks, and load capacity. PLUS, 50k warranty. Maybe it's 45k...it's not less than 45k. LOL
Also, for those curious, the load rating on the 20" Platinum wheels is 3590, they're made by Alcoa, and have a PVD finish (chrome powder coat).
Epic- The door jamb sticker also shows the oem 20s as 8" wide. Been this way since the 20s were released for these trucks.
OP - go with 295/65/20s. This is a 35.5 x 11.50 tire that is rated for the width of the oem 20s, and it has a Load Index of 129 (4,080 lbs each @ 80 psi). I have the Ridge Grapplers in this size on oem 20s.
on
My sticker says the same 8.0. I just went through all my paperwork and bookmarks trying to find where I got the 8.5 from but no go. Ugh, all this time I was thinking otherwise. Sorry for the bad info.
ETIS report! My Plat Diesel shows 20X8.5"
Does anyone know the actual load rating for these wheels? I cannot find it in the TBBAS Specifications.
Epic you're not alone, I have wondered this for a while as i have seen conflicting reports. But I can tell you exactly where in the Ford documentation it says 20X8.5".....
2017 wheel specs are here (PDF page 61). The rating for 20" wheels is 3,590 lbs. This is +\- 100 lbs from previous Super Duty 20" wheel ratings so I am inclined to believe it (or at least consider it to be close enough).
https://www.fleet.ford.com/truckbbas...ps_-_Specs.pdf
