59t-7006 questions??? please help!
Every one in this forum is so knowledgeable i really appreciate you taking the time to help this novice out! I have an 1951 ford f3 that im bringing back to life. I got her running great but im having trouble not grinding the gears.
The transmission case is stamped on the passenger side with 59T-7006 (the internet says thats a 4 spd) i swear could only find 3 gears and
Im pretty certain that 1st gear is a granny gear.
Can you tell how many gears this transmission has by just the #?
Also some one told me it may be a double clutch.
So my ??? Are:
Do i have a double clutch???
Hows many gears does this transmission have?
And this one may sound really stupid, but if it is 4 spd then where is 4th gear?
And could 1st be a granny gear?
P.s. also it has a p.t.o if that matters at all
Thanks in advance for the help
Todd
So my ??? Are:
Todd
I am almost 100% positive that any case with 59T on it, is a 4-speed.
If you take a picture and post it from the top looking down at the shifter base we can tell by the number of shift rails. If it has two, it is a 3-speed. If it has three, it is a four speed. You may have a stuck or misaligned rail preventing you from going into that end of the pattern.
Tom
Tom
You do not have a double clutch.
You do have to double clutch to shift the transmission correctly.
The transmission appears to have four forward speeds.
Fourth gear is slightly to the right of neutral and toward the seat.
First gear would be the granny gear, hard left and toward the dash.
The shifter on the right of the tranny is the PTO shifter.
Edit: If that is a synchronized transmission, someone will correct me on the having to double clutch.
Ill put it all back together with the the new clutch and give double clutch shifting a try thanks!!!
Another random question? Anybody on this thread know where i can purchase just the plate to cap off and remove the p.t.o??? And if the process is just as simple as removing and capping the p.t.o acess?
You have a T-9 non-synchro "crash" box as previously noted. After watching Bob's good double clutch video if you are still having problems make sure that you have straight 140 weight gear oil in the trans not multi-viscosity like 85-140W. This slows down the gears and makes shifting easier and is what Ford recommended originally.
If you are still having a problem you may have a bad pilot bearing that is keeping the trans turning when the clutch is depressed. A shot of PB Blaster or Kroil on the input shaft through the inspection plate may help temporarily but then the trans will have to come out to replace the bearing.
Part #7600 - Pilot Bearing
