Darwin Award Nominee
I did something really stupid today by allowing that damn cell phone to draw my attention away from what I was in the process of doing...........
I stopped for some bulk DEF at a station and had the nozzle in my hand when my cell phone rang and I answered it. While on phone, I took the cap off of the fuel tank and starting pumping DEF into the diesel tank immediately realizing I screwed up big time letting go of the nozzle stopping the flow of death into my fuel system. I pumped approximately a little of 1/10 of a gallon into the fuel tank. In a panic attack, I place the nozzle back into the pump and started the truck up move a hundred feet away out of the way. I immediately stopped the engine and called my service advisor who gave me a number to a wrecker company and told me to call my insurance and start a claim.
I'm hoping 1/10 of a gallon of DEF fluid into approximately 32 gallons of diesel did not make it through the filters and into the high pressure pump and injectors.
Worst case scenario 2 weeks without my truck and $12,000 repair bill.
Sitting here patiently waiting with a 1/2 gallon of scotch.
Please learn from my screw up.
on
I did something really stupid today by allowing that damn cell phone to draw my attention away from what I was in the process of doing........... I stopped for some bulk DEF at a station and had the nozzle in my hand when my cell phone rang and I answered it. While on phone, I took the cap off of the fuel tank and starting pumping DEF into the diesel tank immediately realizing I screwed up big time letting go of the nozzle stopping the flow of death into my fuel system. I pumped approximately a little of 1/10 of a gallon into the fuel tank. In a panic attack, I place the nozzle back into the pump and started the truck up move a hundred feet away out of the way. I immediately stopped the engine and called my service advisor who gave me a number to a wrecker company and told me to call my insurance and start a claim. I'm hoping 1/10 of a gallon of DEF fluid into approximately 32 gallons of diesel did not make it through the filters and into the high pressure pump and injectors. Worst case scenario 2 weeks without my truck and $12,000 repair bill. Sitting here patiently waiting with a 1/2 gallon of scotch. Please learn from my screw up.
Hang in there!
Totally agree, 1/10 gal in 32 gal fuel is 1/3200 dilution so almost undetectable amount. Also no way with truck being moved 100 feet did it get all the way through fuel line to engine. Should be no problem.
Almost had the same scare except it wasn't me... I was on my way back to California from Colorado and stopped for Fuel somewhere in Utah and at this station they had attendants that went to pump the fuel for you. I had went in and bought 2.5 gallons of DEF and while I was about to pour it in my phone rang. I put down the jug to talk and the attendant picked it up and was putting the funnel into the fuel opening. I happened to see it right before he started pouring and just about tackled him lol. Crisis averted but I can definitely see how the mistake would be made. Needless to say he apologized I felt bad and gave him a healthy tip for nearly knocking him to the ground. Good times.... lol
To the O.P.- You ducked the bullet on this one, but if it ever happens again, DO NOT START THE ENGINE. I don't care how many people are honking at you. A new 6.7 plus labor puts a big dent in 20 grand.
Received 6,667 Likes
on
TrikeDawg, thanks for the reminder. I have yet to fill my 2017 F-350 with fuel. I'm going to be a nervous wreck when that time comes.
Dilution rate has nothing to do with it. Def is a water based product and will not mix with the fuel. After more than about the first 3-4 ounces fills the water separator, the rest will pass through to the high pressure fuel pump causing it to lock up. Then the cam breaks and the pistons hit the valves. Thirteen ounces is a fatal dose if the truck runs long enough to suck it up from the bottom of the tank, which is where it will be sitting due to its density. Fortunately if the Water in Fuel (WIF) light hasn't come on, it hasn't got there yet. Drain/dry the tank and re-install it. For the next couple weeks drain the water separator every few days, or IMMEDIATELY if the light comes on. Don't attempt to drive it home first. Pull to the side of the road and open the yellow drain valve and let about 6 oz. out.
