2017 6.2L V8 and Fuel Grade (AKI)
We've ordered a new 2017 F350 with the 6.2L V8, and I've downloaded the 642-page OM for some light reading. I found this interesting li'l blurb on page 184:
I found para #3 above to be rather interesting. Without meaning to start another one of the usual fuel grade wars, have any of you 6.2L V8 owners tried higher-than-"regular" 87 AKI fuel (i.e., 89, 91, or 93) and noticed any difference in performance (i.e., fuel economy, engine response while towing, etc.)?
Thanks!
Jim / crewzer
FUEL QUALITY - E85
Choosing the Right Fuel - Flex Fuel Vehicles
Your vehicle is designed to operate on regular unleaded gasoline with a minimum pump (R+M)/2 octane rating of 87 or regular unleaded gasoline blended with a maximum of 85% ethanol (E85).
Some fuel stations, particularly those in high altitude areas, offer fuels posted as regular unleaded gasoline with an octane rating below 87. We do not recommend these fuels.
For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended. The performance gained by using premium fuel is most noticeable in hot weather as well as other conditions, for example when towing a trailer. See Towing (page 268).
Thanks!
Jim / crewzer
Thanks!
Jim / crewzer
Thanks!
Jim / crewzer
More info from the US Department of Energy if you'd care to learn more about E85.
Alternative Fuels Data Center: E85 Specification
Thanks!
Jim / crewzer
Thanks!
Jim / crewzer
I didn't believe it at first either. I ended up almost walking because I was traveling across country and grabbed the yellow hose by mistake (we don't have E85 where I live). A few miles down the road my truck was running horrible, thought I had gotten bad fuel. I guess I did get bad fuel, at least compared to what my 87 F250 300-6 was designed to run on! Luckily I had only filled one tank so I switched tanks and it started running good again. When I learned what had happened I looked into it more and was blown away that someone decided to use corn for running cars. Where I come from Corn is made for drinking, not running engines!
I won't get into the political aspects of it, but if you do some research on the whole E85 thing it's hard to understand, at least to me. I'll just leave it at that.
Oh yeah, it wasn't my intent to correct you from the standpoint of "you're wrong, I'm right". I just wanted to share the info since it's a new concept to many of us outside the corn belt.
Anytime I've filled up with E85, the ethanol content shows between 50 and 60% on the scangauge...presumably due to the gas left in the tank and the % of ethanol in the "E85". It gets *****ty mileage on E85 I will say.
I have run with a tank of 93 in the heat of summer and it's noticeably better taking off. With 87 and high temps, talking mid-high 90's, I can tell it pulls timing when taking off from a stop with part throttle by the sudden change in intake sound and throttle response. I also notice the idle kicks up at a stop when outdoor temps are high.
how are you reading that on the scangauge? xcode?
The upsides is the really high octane of corn which means a performance engine designed to run on it will make some serious power, but use a ton more fuel doing it.
We've ordered a new 2017 F350 with the 6.2L V8, and I've downloaded the 642-page OM for some light reading. I found this interesting li'l blurb on page 184:I found para #3 above to be rather interesting. Without meaning to start another one of the usual fuel grade wars, have any of you 6.2L V8 owners tried higher-than-"regular" 87 AKI fuel (i.e., 89, 91, or 93) and noticed any difference in performance (i.e., fuel economy, engine response while towing, etc.)?
Thanks!
Jim / crewzer
Thanks!
Jim / crewzer
I have run E85, E10 and straight gas in mine, E85 would be my last option when towing but empty I didn't notice that much difference. I couldn't tell any difference between E10 and straight gas both mileage and power when pulling or empty, my empty is 8700lbs.
I've run a lot of 85 octane in high altitudes and I can tell no difference from the 87 that I had in my tank from the low lands, I think it actually runs a little better but be sure to run it all out of the tank before you drop down in altitude. One time a wrong turn was made and we dropped down to 900ft after being 7 to 8K for a month and it ran fine but with reduced power, I just topped off with higher octane and all was fine but we also went back up to 8K feet shortly after that.
Denny
Thanks for the comments, Gents!
Our '00 F250's (described in signature below) everyday diet is 87, but it runs better on 89 at low- to mid-elevations (i.e., less AT gear-hunting while climbing). I've not noticed any difference in fuel economy between the two grades.
We've used the '00 F250 for a fair amount of traveling and towing in CO, MT, NW, and WY. I always used 87 AKI at higher elevations, and the old truck ran fine up to ~8K feet (i.e., US287 between Ft. Collins and Laramie, one of my favorite drives). However, I've taken it across the Togwotee Pass (~9, 700 ft) in NW WY a couple of times, and performance was noticeably reduced.
I'm looking forward to experimenting with various combinations of fuel AKI, loads, ambient temperature, grade direction, and elevation.
Thanks again,
Jim / crewzer
Thanks again,
Jim / crewzer
