1999-2004 F250 Wheel Well Liners?
When I went to install them the lip on the outside was way too wide and I couldn't get in behind the wheel well lip. IF I pryd it I probably could have but I didn't like the pressure it was putting on the paint or fender. It only took me an extra ten minutes to trace and cut the liner and then it slid right in with zero problems. They have held up perfect and have zero sag or discoloration since the install.
and yes I would DEFIANTLY do it again
I will take some pictures later for you
You can get them from any Ford dealer, or shop online for part number: BC3Z9927886A
These can be installed without removing the tires. You'll see when installing them what I mean by 2 tabs not lining up. Once installed you won't notice since they'll be hidden behind the wheel lip of the inner fender. There's more than enough clips and screws to keep them secure. They'll look like a factory finish once they are installed.
