2013 F250 sag
2013 F250 sag
Hey guys I'm new here. I have a 2013 F250 that I bought not too long ago. It has the 6.2 engine and while it's a great truck, anytime I hook to our flatbed or stock trailer, it sags bad. It only has 3 springs and no overloads and was wondering what is the best thing to do to help the suspension out on the truck. The most I pull is about 10 round bales or a trailer with 8 full size cows. That's for any advice!
-Caleb
-Caleb
My last F250 had the factory overloads via the camper package, they helped quite a bit. Other than adding the factory or aftermarket overload springs, I have used timbrens, and have them on my new F250. They replace the factory bump stops with new, larger ones that contact the axle sooner. I like both options as a rather quick and easy fix versus going to some air bag system.
I think Ford offered 3 different Rear spring packages..
as stated.. the slide-in Camper spring package is the strongest...
my 2012 has it and rear anti-sway bar.
my truck is rated to carry 3,500 pounds.
if still not happy
you can also changed out the 2 inch spacer for spring pack to the F 350 4 inch spacer.
many threads HERE on both subjects.
if still not happy
-Caleb
-Caleb
Ford issued a TSB on the subject that laid out exactly what needed to be done (at the customer's expense) to correct this issue. Unfortunately, if you follow Ford's procedure it will cost you north of $2,000.00 in parts alone!
I chose to go with airbags for a lot less money, but I also tow a greater variety of trailers more often than you indicate. For your purposes, I'd recommend the Timbrens.
Dustin_86
01-20-2005 09:56 PM
