2017 Super Duty Ford Deflector installed
Just 2 issues with my deflector.
One of the holes that the metal clip goes thru wasn't completely cut out of the plastic. Took a little work, but made it fit. Also, I noticed a little rust spot on each headlight, where the clips were already rusting and water with rust was dripping onto the top of the headlights.
Still like it, but I did have those two issues.
FYI the instructions suck big time, the hardest part of the install was putting the metal clips on the deflector. It's a pretty sucky system and I could see if someone is not careful they could break the deflector. So you know all 6 clips will slide into the grooves you see on the deflector, and you have to push them on firmly. Then attaching to the hood is a breeze, well kind of, it may help if you have another person helping line up the clip with the hood holes. I was tempted to put the rubber bumpers on the visor instead of on the hood, but then I remembered if the visor moves a little those bumpers would wear the paint on the hood, so put the bumpers on the hood.
I did under my post on installing the mudflaps. I skipped my side shots, none came out to well.
