The $500 IDI adventure
Howdy folks, I figured I would start a "build thread" on my new purchase.
Got the thing home today, and threw a couple batteries in it. Got it cranking and checked a couple things out. The fuel filter did have fuel in it, though it may have been filled by the PO in attempt to prime the system. Pulling the line to the injection pump revealed no fuel while cranking, and disconnecting the line from the lift pump to the fuel filter revealed the same, dry line. I did not get around to seeing if fuel is getting to the lift pump yet however.
Home safe:
Home safe:
How are the fuel tanks? Could the fuel pickup be broken in tank and maybe the lift pump not getting fuel? In my new to me van, Mine works, but I have more than 1/4 tank in both tanks. But I'm pulling the tanks(project) to check my pickups first and see tank condition.
plus my front tank reads low when it's more than 1/2 full so I need to check for a stuck sensor. my rear tank is working fine, so I'll do the front tank when the temp warms up.
My fuel gauges are really wonky. One reads empty (no idea if true) the other one must be shorted, as it pegs WAY out when I select it. I put a few gallons in the front tank, but I will likely have to keep filling it. Not an easy task with one diesel can and no way to move the truck. As suggested to me eslewhere, I should pull the inlet hose off the lift pump and put it in a container of fuel. If it doesn't suck the fuel up, I know it's the lift pump. I'll keep you guys posted.
Received 3,099 Likes
on
