Ballast wire
Ballast wire
Hey All,
1970 F-100, 390, 3sp O/D, 2wd
Recently I've been going through a tune-up on the truck and getting familiar with it. Reading about the ignition system etc, and realized that I don't think I have a Ballast resistor wire on the coil There is some jenky wiring that was performed by the PO and may have taken it out not knowing because I can't find it. Where should this pink wire with bullet connectors be located on the truck? Is it under the dash or visible in the engine compartment? Because if I don't have one, I want to put one on there. Thanks
Dan
Dan
Another test would be to remove the 'I' terminal wire from starter solenoid. If it still starts the resistor wire has been bypassed.
on
The faded pink resistor wire should have a female bullet type looking wire end connector on the +side of the coil. May look brown or it's all greases black looking until you unwrap the oem tape on it.
The coil +wire may show 9-12 volts not running 6-9 volts running:
The pink wire it located on the ign.switch plug, is where it starts out working it way to the coil.
Orich
Orich
Ok, thanks I will go check that. I checked the coil itself a minute ago and it shows 1.6 ohms between the pos and neg but between pos and the center is only 8.26 K-ohms and what I found said that it should be between 9 and 13 K-ohms. So, it is a bit below the low side. I would like to replace the coil soon and also put Motorcraft points and condensor in it but wanted to hash all this out first in case there is an issue.
Dan
Dan
Dan
Dan
61.49" long / Color coded pink / 1.30-1.40 ohms resistance / #20 gauge wire.
ALL 1960/70 FoMoCo vehicles.
Hey, thanks much for the part numbers Jeff and Bill. That is great. I found that Summit sells the points and condenser, so do you think those are what I'm looking for? And do you think I would gain anything in quality by buying a NOS set off say Ebay or something? Just curious. One last thing, Do you think that an AC Delco coil will be my best bet on quality? I know how critical these components are. Thanks again
Dan
Dan
