Doing F250 rear brakes
Old 01-23-2017, 03:55 PM
hoss73ford's Avatar
hoss73ford
hoss73ford is offline
Cool Doing F250 rear brakes
These are the heavy duty ones with J hook shaped hold down pins. I cannot get the small spring compressed enough to go behind the pin while holding the shoe in place. Is there a special tool for this? NAPA or any retailer part # appreciated. I've already smashed my hand and knuckles a couple times.
Old 01-23-2017, 06:19 PM
tabascom16's Avatar
tabascom16
tabascom16 is offline
Confused here. The return spring as in this diagram or the hold down pins?
Old 01-23-2017, 07:44 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
OP's truck has 12" x 2 1/2" rear brakes aka heavy duty brakes.
The pic you posted is for 12 1/8" x 2" rear brakes that use different hold down springs.
Old 01-23-2017, 07:54 PM
somethingclever's Avatar
somethingclever
somethingclever is offline
I just use vice grips or pliers and grab the spring and push into place and position the pin with the other hand.
Old 01-23-2017, 10:07 PM
Justin73supercamper's Avatar
Justin73supercamper
Justin73supercamper is offline
I made a tool out of a large wide screw driver. I ground a notch in the end that is wide and deep enough to hold the spring. Then just push the spring down and put the hook on
Old 01-23-2017, 10:44 PM
DB429SCJ's Avatar
DB429SCJ
DB429SCJ is online now
Snap-On makes one. Their website has it for $26.50.#B1359B
Old 01-23-2017, 11:14 PM
hoss73ford's Avatar
hoss73ford
Ok thanks, I'll check on Snap On's site. Vice grips wouldn't work as none are big enough to fit over a 2 1/2 inch shoe & I've never seen that wide of pliers either. The pic at the bottom is the same as mine.
( mine being a 1972 F250 rear end with 3.54 ratio going into '66 F250)
Old 01-24-2017, 11:11 AM
somethingclever
wow that is a large picture?
Anyway the vice grips don't go on spring and backing plate - just grab the spring stem with the pliers and push in the right direction. The shoe will stay in place.
Use your free hand to align the j-hook to the spring stem.
A wide flat blade screw driver with a notch is also a good idea.
Old 01-25-2017, 09:33 AM
hoss73ford's Avatar
hoss73ford
Thanks guys. I ended up getting a flat 1" wide chisel and grinded a slot in the middle of the blade to use as a tool & C clamped the shoe to hold it in place. The spring was still a bear as I can sometimes be weak as water but I got it on. The rest is easy.
TomsBeast
28
05-14-2020 10:02 AM
jwmayfield
18
07-22-2013 03:32 PM
ruddy
Bronco II
04-23-2012 09:37 AM
Quick Reply: Doing F250 rear brakes
