Degreased my heads, PROGRESS UPDATE
Old 01-21-2017, 10:28 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,600 Likes on 1,446 Posts
I took advantage of the 50° weather today and degreased the heads I bought from Dennis, pinto plumber. Now they ready for red paint.
Old 01-21-2017, 10:40 PM
abe's Avatar
abe
abe is offline
Question, do I need to scuff up the paint before I repaint? Like with Scotch Brite?
Old 01-22-2017, 12:12 AM
mOROTBREATH's Avatar
mOROTBREATH
mOROTBREATH is offline
It wouldn't hurt, but the most benefit will come from truly degreasing and decontaminating the surface--that is what will cause most of the adhesion issues. (And since they are old engine parts, doing a sufficient job of decontaminating will be very difficult)
Old 01-22-2017, 01:54 AM
Normalbloke's Avatar
Normalbloke
Normalbloke is offline
I'd personally get them vapour blasted properly.
Old 01-22-2017, 04:13 AM
seaves46's Avatar
seaves46
seaves46 is offline
Spray on oven cleaner works a treat , it strips the oil and grease and will even remove the old paint , give it a try .
Old 01-22-2017, 06:51 AM
pintoplumber's Avatar
pintoplumber
pintoplumber is online now
Abe, I used Bill Hirsch's engine paint. Painted it up at Ober's shop. The heads would have been clean from him hot tanking them. So I believe the base coat you have there is good. I think a scuff would be good. Dennis
Old 01-22-2017, 08:35 AM
wmcewan's Avatar
wmcewan
wmcewan is offline
Looking great Abe
Old 01-22-2017, 10:11 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
A bit of a hijack but has anyone had any luck finding the truck Y Block yellow that's on these heads? Sure would like a source.
Old 01-22-2017, 11:10 AM
abe's Avatar
abe
abe is offline
I bought my engine paint at Advanced Auto. It's made by Duplicolor. I don't know for sure but I would think they have yellow.
Old 01-22-2017, 11:15 AM
bjmayberry2
Thanks Abe. I bought Daytona yellow engine paint but it is much brighter than what's on your heads.
Mine
Yours
Old 01-22-2017, 11:39 AM
pintoplumber
That was packard ivory from Bill Hirsch, my engine came from a 54 car. Dennis
Old 01-22-2017, 11:49 AM
bjmayberry2
Truck Y Blocks had a yellow lighter than my engine that looks similar to the heads. I can't seem to find Ford engine yellow anywhere. The yellow on my engine is growing on me since I painted it and since I'm not, by any means, going back original I guess my yellow engine will just have to do.
Old 01-22-2017, 09:08 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is online now
If you don't strip off the old paint there is a product sold under different names but one of them is Sand-Free. It is a liquid you spray or wipe on and it etches the exiting paint so the new paint has a way to grip the base (old) paint. I use it in door jambs and other hard to reach areas with great results.
Old 01-22-2017, 09:28 PM
abe's Avatar
abe
abe is offline
Thanks guys for all the tips. I was hoping to paint them today. The paint can says you should paint when it is between 60° and 90° but it only got up to 50 today and it was damp. So I'll have to paint them in my buddies heated shop sometime in the near future.
Old 01-24-2017, 02:07 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Aervoe makes the best engine enamel, once you use it you will never use anything else. This is a professional product used by many in the engine building industry and as such it is not available at your DIYer outlets. Sticks to any metal without a lot of prep and is impervious to most chemicals and heat. I buy it by the case.
Quick Reply: Degreased my heads, PROGRESS UPDATE
