1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
03 Front Brake Locking Up/ New Lines?
Old 01-20-2017, 08:56 PM
reptar0077's Avatar
reptar0077
reptar0077 is offline
-2003 5.4 XLT. 178,xxx Disk brakes front & back.
Driving home from work, came to a long stop waiting for train. Started to drive away and my front right brake started to lock up pretty good on me. Drove it home as I was only a couple blocks away. Its just started to get above freezing here, and we've been between 0-20 degrees for a good stretch lately. That being said, I'm pretty sure its my brake lines swelling with our "heat wave" of 35 degrees today. Also I've replaced the rear rotors & pads, as well as flushed the brake system a while back. Never replaced the front after purchasing used a while back, as they still had plenty of pad left.
Question
1. Anyone else had this issue and fixed it with new lines?
Edit: Purchased new front lines.
2. Do the front calibers, "float" on pins like the back?
(If so that may be my issue of the caliber getting stuck on the pins moving back and forth.)
At 178,xxx miles I'm going to replace the lines myself regardless of this outcome. Just looking for similar experiences & any helpful tips along the way. Thanks!!
Old 01-20-2017, 11:27 PM
firebirdparts's Avatar
firebirdparts
firebirdparts is offline
These trucks routinely suffer from sticking brakes. The pads themselves stick after some "rust growth" and the calipers also stick internally (piston issues). After 178,000 miles you probably could use a new caliper on there.
Any car can have a caliper stick on the pins. You look at the pins and you be the judge on that. But I don't think Super Duties are actually all that bad about the pins.
Old 01-20-2017, 11:32 PM
Copper.Farm's Avatar
Copper.Farm
Copper.Farm is offline
Drivers front brake line is always first to go.
Old 01-21-2017, 02:11 AM
reptar0077's Avatar
reptar0077
That's a good point about possibly replacing the calipers. I was thinking about rebuilding them after possibly dreading the costs. But after looking at Napa online brand new re-manufactured calipers with hardware are actually really decently priced. Provided they have any. At 63$ each so 126 plus tax.
https://www.napaonline.com/napa/en/p...341_0206182683
Thanks for the thought! I'm going to do the re-manufactured calipers with lines at the same time.
Also my back pins on the truck at the time were really pretty good considering. The trucks braking system as is seems really decently sized for what their apple to handle.
That makes sense that the front would go first. The front brakes do 70ish percent of the braking anyways with the weight going forward. Hell my wifes Hyundai Sonata is at 112xxx with original disk pads on the rear! I was going to look at them soon for any glazing or "glassing over".
Old 01-21-2017, 09:07 AM
99f350sd's Avatar
99f350sd
99f350sd is offline
Lines are fine do the calipers.
Old 01-21-2017, 10:04 AM
erikkloss's Avatar
erikkloss
erikkloss is offline
Question
Yes, the front calipers float on pins just like the back. I have seen many of the super duty trucks with the pins frozen stuck or sticking from rust. This will cause a brake to lock. New calipers don't come with the pins and bracket. If your pins are frozen, you might be able to get them out with a good penetrating oil like PB Blaster. If you can't you will have to buy new caliper brackets.
Old 01-21-2017, 10:25 AM
jetjockey99's Avatar
jetjockey99
jetjockey99 is offline
NAPA does have remanned calipers that include the bracket and new pins, it is the best way to go. My '03, new had problems with the bracket being machined wrong, too tight a fit for the pads at less than 15K, I was on the road and couldn't get into dealer quick enough so I replaced with OE pads and found that even after cleaning all rust off the brackets the pads fit extremely tight, so I filed the opening just enough to free up the pads, I have since done this on many SD's and have found that remanned calipers with brackets seem to have more clearance than the originals and reduces or eliminates the problem. I have found the same problem on the rears of some SD's and even OEM remans have more clearance, just enough to allow the pad to move with out binding, but not enough to allow them to rattle.
Old 01-21-2017, 03:55 PM
reptar0077's Avatar
reptar0077
Probably true. All do the calipers to start. Just didn't like the thought of having to re-bleed the system again if the lines were bad.
I didn't see this online? You just ask them, or they offered them, & they had a set included? All have to call tomorrow & ask. Do you know what you payed roughly for 1 or both?
Thanks!
Old 01-21-2017, 07:12 PM
thomabb's Avatar
thomabb
thomabb is offline
The rubber brake line that runs to the caliper can delaminate on the inside. When it does it will not let brake fluid pressure bleed back away from the caliper. Those hoses should be replaced about every third brake job.
Old 01-22-2017, 03:35 PM
reptar0077's Avatar
reptar0077
Thanks for that info, at this point I'm going to do the lines to.
By the way your signature is hilarious.
"Single Cab (perfect for my anti-social tendencies)"
Old 01-22-2017, 04:26 PM
thomabb's Avatar
thomabb
thomabb is offline
Yea when I bought the truck I asked my wife "what do I need a back seat for?"
Old 01-22-2017, 06:28 PM
reptar0077's Avatar
reptar0077
Purchased new lines & front caliper.
Man Napa seemed to have a really good price on a rebuilt caliper!
Looks sweet! Installing later in the week.
The guy recommended red thread locker on the brake line. Really red?? I always thought that was for permanent, aka never hope to get off again. Wouldn't blue be fine?
Also anyone know the torque for the caliper bolts? Thanks!
EDIT:
Torque Specifications Front
Description lb-ft
Disc brake caliper pin bolt 42
Front brake hose bolt 26
Front disc brake caliper anchor plate bolt
(Excursion, F-250, F-350) 166
Old 01-22-2017, 07:21 PM
thomabb's Avatar
thomabb
thomabb is offline
Why would you need thread locker on the brake line fitting? It never sees any torque?
Old 01-23-2017, 01:18 AM
reptar0077's Avatar
reptar0077
Vibration I guess? I was just going to just use a drop of blue lock tight like I do on everything I've ever done.
He said he used red lock tight for the high temp. Red lock tight isn't high temp unless specified on the bottle. To each his own I guess.
Old 01-23-2017, 08:08 AM
thomabb's Avatar
thomabb
thomabb is offline
I wouldn't want to risk getting thread locker inside the hydraulic system.
69oiler
01-30-2019 08:15 PM
fairlaniac
16
08-07-2018 06:10 AM
akorcovelos
34
03-14-2017 08:40 PM
tworock
Aerostar
11-03-2008 09:40 AM
dswan101
10-28-2004 11:15 AM
Quick Reply: 03 Front Brake Locking Up/ New Lines?
