Brake pedal is pulsating bad hard to turn wheels
Can i get some advice I am at the end of the rope on this truck. Took it to ford for warranty issue on alternator. Noticed a noise like a pulley bearing tight or belt tight. Took it back to ford they said belt was causing the problem so it was replaced. 2 days later i go to use the brake and notice a noise and the pedal is seriously pulsating thru the firewall it feels like. Went away and then came back and now turning the wheel is causing a noise? I don't want to go back to ford? Anyone had this problem.
I need some help please.
Thanks
Thanks
For the belt, I don't remember if that pulley is on the rib or back side of the belt but I meant just make sure it is riding on the pulley correctly. Since the belt was just replaced, then maybe it has something to do with that or it could just be a coincidence. Also make sure the belt is good and tight and there isn't an issue with the tensioner. It would be good to have someone else in the truck to duplicate the issue while you are looking under the hood.
Here is a similar post.
https://www.ford-trucks.com/forums/1...g-pulsing.html
Another
https://www.ford-trucks.com/forums/1...d-kicking.html
Another
If you think about the sequence of symptoms and consider that the original diagnosis by the Ford tech may have been wrong, you might make some progress.
What if your power steering pump has been starting to bind up because of a bad front bearing. Then the belt starts to squeal from the additional load. You replace the belt with a new one that grips better, so the noise goes away. But the pump is still the problem, so you notice eventually that the brakes and steering are affected.
It isn't the truck that is the real problem, it is the incorrect diagnosis. So to fix that problem, you should decide whether you would be better served by an independent shop that specializes in 7.3 trucks and has employees that can analyze. There is a big difference between a troubleshooter and a parts changer. The art of logical thinking is not practiced by all mechanics. That said, we all make mistakes, so maybe your mechanic usually does a good job for you, so no need to change.
Larry
Larry
Larry
Larry
I don't visit here as much as I used to, but I hope next time you have an issue, you come back to this forum first and use the dealership as your backup. The knowledge in this forum is phenomenal, and I'm not saying that your Ford tech isn't competent, but it's unlikely they have the wealth of knowledge of the forum members here, past and present. Ideal situation is that your Ford tech is a regular reader of this forum!
Glad you got everything sorted!
