Air Scoops on 56 Big Jobs
Old 01-17-2017, 07:07 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
I thought all 56 Big Jobs had the air scoop on the hood? but I've seen a lot of 56 Big Jobs without them. Like this C-800 Big Job:
Were they an option or didn't the C series have them?
Edit: just found a pic of a Big Job conventional cab without the scoop:
Old 01-17-2017, 08:38 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
May have been an engine option based use?
Curious about the answer as well.
Ive had my eye on a 56 dump truck local for a while now that has the scoop on it.
Maybe I should gouge my eyes out though!
Old 01-17-2017, 09:32 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is online now
Only 332 with a 4 v carb had the hood scoop. And a big job could be had with a 2 v carb and would not have a scoop
Old 01-17-2017, 10:56 PM
abe's Avatar
abe
abe is online now
Thanks, Kevin. If anyone would know it would be you! Could C series trucks be bought with a 4 barrel? I don't think I have seen a cabover with a scoop. It may be because of the different air cleaner set up.
Old 01-18-2017, 02:05 AM
Mixer man's Avatar
Mixer man
Mixer man is offline
I was under the illusion that the hood scoops indicated one of the Super Duty big block engines was in it (401, 477, 534).
Old 01-18-2017, 06:38 AM
bigwin56f100
Not in 56 as those engines are for newer models
Old 01-18-2017, 10:19 AM
1952henry's Avatar
1952henry
1952henry is online now
4V=hood scoops was always my impression.
Old 01-21-2017, 07:41 PM
Effies 56's Avatar
Effies 56
Effies 56 is offline
Ok guys now you have peeked my interest just a little more. The 56 F800 that I was looking at had the scoop. The owner believes it is a Lincoln 317. Maybe it is/ was a 332?
We never got the hood open when I was there. And even if we had I would not have been able to tell the difference at this time. I mean I know what a Y block looks like, but don't have the info to tell a 317 from a 332 from looking at the engine, yet. So is a 332 even harder to get engine parts for????
BTW there was a group of rough trucks in another Big Job thread, The yellow one (F800 dump) did not have the scoop.
The Big Job scoop!
Regards,
Chris
Old 01-21-2017, 09:17 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,108 Likes on 2,642 Posts
Maybe this will help you
LINCOLN Y
Old 01-21-2017, 09:37 PM
dadgonebroke's Avatar
dadgonebroke
dadgonebroke is offline
Terry's F100 Parts
If I remember correctly, Terry's is reproducing these in fiberglass.
Old 01-21-2017, 09:46 PM
Effies 56's Avatar
Effies 56
LINCOLN Y
John,
Thanks! Yes that may help! I just noticed you have 81,000 + posts! WoW!
Regards,
Chris
Old 01-21-2017, 09:47 PM
56panelford
Originally Posted by Effies 56
John,
Regards,
Chris
Ya...I BS a lot...
Old 01-22-2017, 10:03 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
B6Q-9671-A .. Carburetor Air Cleaner Air Duct (less grille).
1956 F750/800/900 302/332 with 4V carburetors. These two Lincoln derived Y blocks were introduced in 1956, used thru 1963.
401/477/534 introduced in 1958. 401: 1958/76; 477/534: 1958/81.
Old 01-22-2017, 09:32 PM
Effies 56's Avatar
Effies 56
Folks,
Ok this has a cable system to the air duct with hand control in the dash. Was this the choke or something else? What's the scoop? (Pun intended)
Regards,
Chris
Old 01-23-2017, 01:09 PM
NumberDummy
B6Q-9678-A .. Carburetor Air Cleaner Air Duct Control (cable) Assy. / Obsolete
1956 F750/800/900 302/332 w/4V carbs.
See 9678 in parts catalog pic in post #13.
Quick Reply: Air Scoops on 56 Big Jobs
