Header rubbing motor mount '73 F250
Good Morning, Gents!
About 1.5 years ago I installed a set of cheap headers on my '73 F250 2wd. Flowtech full length (O'Reilly) and it's the LAST time I ever buy cheap headers. I've been blowing gaskets like crazy. I just double up the passenger side gasket and it seems to do the trick (so far). Anywho.....
Attached is a picture of this header just barely rubbing on the passenger side motor mount bracket. Is this a result of cheap design on a set of cheap headers? Or will any set I buy do this?
Slowly but surely I'm fixing this truck up. She sat for 10 years in the AZ sun and dry rotted. She's steady and strong, now I'm just working out the kinks.
Good times with headers
I don't think its all that uncommon to have a rub or a tight fit with headers... I just put my new Flowtech full lengths on and it was a B!t(h on the passenger side and yes I have a rub also on the motor mount.... And when comparing to the headers I took off the passenger side, they too rubbed on that same motor mount... And I installed new motor mounts between removing the old ones and installing the new ones..... So its just a matter of the perfect fit in a tight spot................. I used RemFlex header gaskets and they are the Shizz ! No leaks on first start up and none yet..... Ill pay that $30 all day............ To each his own, but the rub on the motor mount is the least of my worries....... and to clarify mine is touching on the metal support bracket that supports the rubberized motor mount.... I don't believe any significant heat transfer would take place there which would create a safety issue.... Although I wouldn't put my tongue on it......
inwas thinking the same thing. I'm sure the motor mounts are pretty old in this ol girl. Even if it did the trick or not, I'd still want piece of mind by replacing them.
Woukd shorty's be better?
What did you do at the collector? Mine is about 1/32inch away from the frame. It's a stupidly tight fit. I have a feeling it's rattling there too but I can never make it do it while I'm under the truck.
my tank is under the bed so I had to have some custom tubing done at my local shop. Not much space to run true duals.
Tight fit
Yes its way tight ! I didn't do the pipe work back from the collector but it loops up over the frame and if its not touching its about a thousandth's of an inch off of it ... But looking at the underneath of the truck, I don't know how else you could route it.... Sucks I know, it took me and my son several hours and 'time outs' to get our passenger side headers mounted I don't have a good answer or solution for you, other than some $$$ custom exhaust work.... It does surprise me that you could feel that vibration from the exhaust system ? Not second guessing you, I just didn't think it could amount to that unless there is something loose and not buttoned up good at the collector ?
But fitment wise maybe someone else can chime in.
Hmmm..... good idea! Are those motor mounts adjustable on the perch? (I'll most likely do motor mounts anyway. I'm sure these are stock)
The small town I live in.... I've found a family member of the original owner who told me this truck was never driven (relatively speaking) and that my odometer was true at 80k (at the time I bought her a little over a year ago). It was custom ordered out of Alamosa, CO with a Dana 80 rear and several other things that I'm finding out as I go along.
I loosened both motor mount (insulator) nuts, jacked a 2x4 vertically under the oil pan rail and leveled 'er up. Solved.
jlang
04-13-2010 09:34 PM
paulmello
07-15-2003 08:42 AM
