Engine block heater noise?
I have a quick question/opinion poll about using my old factory block heater. The short of it: I have a 1990 F350 with a 460 in it, and it came with a block heater, which has not been used for quite some time. A couple years ago, the passenger's side freeze plug/heater element sprung a leak and was replaced with just a standard brass freeze plug. My two questions are: Is it okay to/would you run an old block heater in only one side of the engine, and is it normal for this heater to make a hissing-like noise when operating? It sounds like water boiling in an electric kettle. I am just concerned about this because like I said, this equipment has not been used for a long time. The reason why I am using now is because we are in for some pretty low (sub-zero) temps here in Anchorage for the next week, and I would like to give the truck a little boost in the morning. Any and all thoughts/comments are appreciated. Cheers!
Yes, you will hear them "cooking" I personally have never seen one with more than 1 freeze plug heater.....If I am not mistaken that's how Ford sends them out of the factory ........there may have been an option for 2 of them ......not sure.......and I'm sure that someone somewhere has installed 2 at some point.......you are fine!
dlpinkc
01-08-2004 10:28 PM
