Will first gen psd headstuds fit 7.3 idi?
So found a really good deal on some first gen psd headstuds and i want to eventually throw a turbo on my 7.3 idi na and i know the first thing you have to do before increasing compression is replace headstuds. So will the headstuds for a psd fit my 94 7.3 idi na?
7.3PSD is 12mm, the 7.3IDI is 1/2", so no. R&D has the 7.3IDI stud kit for a very good price.
You can do the studs one at a time if you're careful, at least I know you can on the 6.0. Just take the head bolt out, thread the stud in, paint it with Ultra Torque and then spin the nut down. Make sure you do the full torque before going on to the next one.
After my experience of breaking some bolts trying to get them out, im not sure i would even try to retorque them, unless you pulled em and lubed them (assuming you could get them out) Also, 7.3 headbolts permanently stretch when torqued just a little over stock spec. 6.9 bolts however, seem to be alot better quality.
4rdzilla
11-27-2005 11:19 PM
RawPower
01-12-2004 10:11 AM
