Anyone got a crankshaft pulley?
Here's your pulley. Ross has the correct current number, which Parts Voice doesn't find any anywhere. I also checked the old books for numbers EAG 6316 B/C/or E which are the earlier number changes I found. Also nothing found on Parts Voice. So let me see if I can get it pulled without doing any damage to it. Will report back tomorrow. Stu
I've soaked, mildly heated, and tap tap tapped without moving it. And gave it a mild amount of torque with a regular puller so as not to hurt it. Nothing. The shop manual shows there are two threaded holes for the correct service puller to be screwed into its center. Which I don't have. So I'd suggest you keep looking while I continue to soak, heat, and tap. Worse comes to worst I'll make a puller to match the one pictured in the manual. If GoldCo has better luck hooray for him. If you find one please say so I can leave the beast to rest. Stu
Stu, Autozone "loans" the appropriate tool, although at $15 I'd consider buying it.
OEM Industrial timing gear/pulley set 27009 - Read Reviews on OEM #27009
