04 6.0 will run great then eventually die
2004 later year 6.0 F-350. 155,000 miles. All stock.
It will start and run fine. Drove it for an hour then began running rough. Nursed it back home. When idling it eventually died. It will eventually fire up but runs really bad. It has done this a few times
Ive done fuel filters and 911 fuel treatment because thought it was gelling. No help.
It has injector circuit fault codes that pop up. Only other code is MAF sensor low but in range. First it was codes for cylinders 3,5. Then 3,5,8. Then 1,3,5,8. Now just injector 1. Keeps changing as I refresh. Battery power fine. FICM is 47.5- 48volts and in sync. ICP at idle is 600-700psi. IPR is 25%.
We had a problem with blowing turbo pipe off so may be overboosting. Not sure. No code thrown relating to that.
Possible wire chafing? Maybe bad tank of fuel? Not sure where to turn at this point. Any help would be appreciated. Thanks
Sure it's not starving for fuel? Has it ever had the blue spring update done?
So it will start fine, cold, all the time but when hot will die at some point?
I wonder if the injector codes can be caused by the lack of oil.....just thinking out loud here, if they are triggered once it starts to starve and die.
What were you seeing for ICP/IPR warmed up and running down the road?
Also possible those codes could be a harness not fully seated in the FICM
2004... old pump
hot idle 650rpm, IPR 25% is high, means it's starving for pressure. The IPR is giving more than it should to keep it at 650rpm.
Clean the MAP/EBP sensor, may be why the CAC tubes blew off. Could also be a sticking turbo.. Clean the boots with brake cleaner, clean the tubes and then spray them with hairspray and quickly put them back together.
Watch the IPR% as it starts to die while running down the road. It should show a spike in IPR% and a lowering ICP and then it will stumble, seem gutless.
Pumps dying
were the codes high or low injector or contribution?
Pumps dying
2004... old pump
Pumps dying
Pumps dying
Also I should note that my employee was driving it when it died the first time. Just shut of going down road. Tried starting it. No go. Assumed fuel gelled. 10 degrees out. When we finally got around to working on it later the batteries were low. Barely cranked then just click click. Used jump pack but not enough. We pulled batteries and recharged overnight at my shop.
So possible damage to FICM because of low voltage? I plan on working on it later and will report back.
I will check all of that this afternoon. Thanks!
No work on HPOP system. There is about 5-7k on alternator.
Just finished running it again and collecting some info.
There were two injector codes left from the last time it ran:
P0263 Cyl 1 injector circuit contribution/balance fault
P0269 Cyl 3 injector circuit contribution/balance fault
Also P0113 intake temp circuit high input
I hooked up fuel pressure gauge and it read 78-80 psi KOEO
Went to start and the batteries were low. Couldnt crank. I may have left something on and it drained past couple days. Not sure. Jumped it with other truck. Charging system seemed fine. Once started truck idled just fine.
At cold idle:
ICP started at around 1200psi and slowly dropped to 1100 as it idled.
IPR % was at 31-33% then slowly dropped to the high twenties.
Fuel pressure remained at 78-80
Driving down the road under load
ICP Around 2000 psi
IPR 50%
Fuel pressure 78-80
We didnt get far down the road. As it ran it started to act up and slowly die as usual. ICP remained around 2000 psi and IPR was at around 50% as the engine shut down completely. We let it sit 5min then tried starting. It fired up and we were able to run it back to shop which was about 300 yards away. It was sputtering but made it back
Theses numbers are while running rough idling back at shop coolant temp of 185 to 190 idling
ICP 640 psi
IPR 24%
I have not cleaned the map or ebp sensor yet.
At cold idle:
ICP Around 2000 psi
IPR 50%
Fuel pressure 78-80
ICP 640 psi
IPR 24%
Pull the IPR and clean the screen. Then verify your FICM is plugged in correctly. Make sure all three plugs are snapped into there sockets.
Once the trucks at full temp, give me ICPV and IPR for idle and 2500rpm while in park.
ICP at 640 is good, IPR at 24% is good, fuel at 78 is high. IPR is a little high, why I want 2500rpm in park. That fuel pressure is high, almost to high. Truck tuned? Aftermarket fuel pump or fuel system? Regulated return?
