Bright'n ur up
Here is what I used, and so far (12 months) so good:
Tail lights:
2PCS Aaron Red 3157 (3156 3057 3056) High Power 5730 33SMD LED Bulbs for Turn Signal Brake Tail Lights Here
Dome lights:
Cutequeen 42mm 1.72-Inch 16-smd 12v Festoon LED Dome Lights, White, Pack of 4 Here
Reading lights:
Cutequeen White 42mm(1.72") 8-SMD 12V Festoon Dome Light LED Bulbs 211-2 212-2 569 578 - White (pack of 8) Here
Clearance / tag / glove box / side markers:
JDM ASTAR 10pcs Super Bright 194 168 175 2825 W5W 158 161 T10 Wedge High Power 5630 SMD 6000K LED Bulbs, Xenon White(Best Value on the market) Here
Fog lights:
JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H10 9140 9145 LED Bulbs with Projector for DRL or Fog Lights, Xenon White Here
Headlights:
80W All-in-One 360° LED Headlights - Cool White 6000K 6K - Dual Hi / Lo Beam - Super White - 8,000 Lm - 9007 / HB5 Here
3rd Brake Light:
Ford Super Duty/Ranger/Mazda B-Series LED 3rd Brake/Cargo Light (Chrome Housing) Here
Front blinkers:
2PCS Aaron Amber 3157 (3156 3056 3057) High Power 5730 33SMD LED Bulbs for Turn Signal Blinker Light Here
Reversing / back up lights:
2PCS Aaron Pure White 3157 3156 3057 High Power 5730 33SMD LED Bulbs for Brake Tail Backup Reverse Lights Here
I am very happy with my set up so far.
You will need one of these if you do change all your blinkers out:
CEC Industries EF27L Electronic Turn Signal Flasher Relay, LED Compatible, 5 Prongs, 12 Volts Here
The L suffix is the key (as I learned through trial and error!) I got mine for NAPA for cheaper IIRC
Hope this helps?!
Tail lights:
Dome lights:
Reading lights:
Fog lights:
Headlights:
3rd Brake Light:
Front blinkers:
Hope this helps?!
When I first switched my interior bulbs to led, I had the bright white ones. I ended up switching to warm white and it made a huge difference. The blue hue with bright white wasn't cutting it for me. The warm white ended up being a lot brighter and easier on the eyes. I ended up replacing my cargo lights and license plate bulbs with warm white to. Again, much brighter than the bright white. If you replace your marker lights up front, I would recommend getting Amber led's. Same goes for your door lights. Red bulbs rich lean the color up much better. The white led's, make it a very light yellow and the ambers make it much more vibrant. I've yet to find a good Amber 3156 bulb for the front turn signals that produce as much useable light in the stock housing as the incadescent bulbs. Everyone I have tried just doesn't shine as bright.
Again, you are more than welcome!
One word of caution, and a chance to learn from my mistakes. The Aaron lamps seem to be the best I have found for the flashers. I have tried going the cheap route and ended up buying three different brand before I found one I was happy with. The cheaper ones work great in the day for the blinkers / brakes, but there was a severe lack of differing light levels from the regular tail lights to the blinker / brakes at night. The Aaron ones have a good difference between them, to me the extra cost is way more than worth it from a safety point of view....
Like I said, this is exactly what I run on my truck (pulled the info from my past Amazon purchases), and so far are extremely happy with the way they work.
When you do change them out I would advise not replacing the high beam indicator or the air bag light. When you use your high beams, you have to hold your hand at the 12 o' clock on the wheel, otherwise you will be blinded. The blue led is nice, but way too bright. And the air bag light will faintly glow. I recently put my stock bulbs back in those two locations because of that.
