3rd Axle Seal and Still Leaking
Old 12-09-2016, 05:29 PM
Lesvoo's Avatar
Lesvoo
Lesvoo is offline
Not sure if this is the right forum but here goes...I have a 1983 f/250, 4wd, 460 that when I bought it the owner had just put new axle seals in the rear hubs when he did the brakes. Unfortunately, he didn't do the brakes right and I had them redone about a year later. In that time the seals had started leaking again so I had them replaced when the brakes were redone. They went about 3 months and both started leaking again. The right one is leaking BAD.
I assume that the axle shaft must be worn slightly keeping the seal from sealing correctly. Is there any way to fix this without replacing the shaft? Not really in the budget right now. I heard about a sleeve called a supra sleeve or something to that effect. Does anyone have experience with them? Thoughts? Are they something I can install myself? I am not a mechanic but have done lots of repair work over the years.
I appreciate any input.
Cheers!
Les
Old 12-09-2016, 07:37 PM
96Forge's Avatar
96Forge
96Forge is offline
Have checked the axle vent, if it's plugged it will make a seal leak?
Old 12-09-2016, 08:58 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
I also agree on the axle vent (look where the brake line from the master cylinder Tees to both rear wheels), the pressure that builds up inside the axle housing from the heat will push the fluid out the end seals if that vent isn't open.
ebbtide
01-18-2019 05:12 PM
Teamrope
11-05-2018 10:22 PM
Liquid10Rider
05-08-2011 09:40 PM
djmac
04-15-2008 01:52 PM
grelch
04-07-2007 12:33 PM
Quick Reply: 3rd Axle Seal and Still Leaking
