Opening a door with malfunctioning latch
2004 4 door F350. Rear driver side door handle snapped the other day. Still worked from inside and carefully from the outside. Got a new OEM handle and installed it. Pretty simple, worked fine.
Later that day, it would not open from the outside, felt like it is locked. Big surprise now it no longer works from the inside.
Got the panel off, looked at all the linkage, seems intact, tried a screwdriver to help move levers along. No luck.
Stopped at a body shop today, they said they think the latch has failed. Can leave it with them.
I really want to work with his out myself, but how can I get that door open?
Don't see much on the topic checking on google.
Thanks
Thanks
remove the part you installed.. reach inside and move linkage to unlatch lock.
go from there.. something else broke. or came apart .
if necessary, remove lock/latch assembly and oil/grease.. inspect...
that is what the body shop would do anyway, or just install a new one.
fyi. most small shops.. (NOT body shops) deal with this weekly. aka corner repair type gas stations.. if any in your area...
Aus56
22
10-22-2022 12:09 AM
Mocha Joe
06-26-2013 08:28 PM
jmcgee
01-16-2012 01:33 PM
tdister
General Automotive Discussion
02-20-2006 09:39 AM
TallPaul
01-15-2006 07:22 PM
