Vacuum line?
Then it isn't the vacuum lines to the hubs
Start with checking the vacuum hoses under the hood that lead through the firewall. Check the other lines that are tee'd into that one. Those vacuum lines near the battery seem to degrade due to the battery. Check the solenoid that supplies the vacuum to the hubs when energized, those solenoids have a bad habit of cracking and leaking vacuum all the time. Check the reservoir.
