PCM Advice needed
PCM Advice needed
I think I am going to have to replace my PCM and I have a 1994 1996 and 1997 available to pull parts. I don't know the configuration of the vehicle until I get there.
My question is will one of those years work on my 95 and can I use one from an automatic or must it be a standard M5OD like mine. Or anything else I need to I need to know? Thank You in advance.
If those donors are F150s then the only viable one is the 1994. 1996 is OBD-II and the 1997 is a completely different generation OBD-II computer. Since a 1994 F150 with an automatic would have an electronic controlled E4OD transmission the computer is not going to be happy when it does not sense all the transmission solenoids and MLPS on the driver side of the transmission.
You have a calibration code on a sticker in your driver's door jam. The calibration code is important to know what components on your truck are matched to each other. For example, the PCM must be matched to the correct EGR valve or you will likely experience bucking and hesitation.
You can get the correct reman replacement PCM/ECU on Rock Auto for $176 minus a $45 core, or on Amazon for $175...probably a safer bet.
It is a 4.9 and I don't know what numbers need to match so I can compare. Which numbers on the picture are you referring to?
ElderC
12-14-2011 03:52 PM
