Which fly wheel to run with AOD
Automatic transmissions don't use flywheels.. It's a flex plate you are seeking.
What year is your engine? Cuz yes, it makes a difference which flex plate... a late 302 requires a 50 oz. imbalance. Early Windsors, 81 or 82 and earlier (I forget which), use a 28 oz. imbalance.
No feedback in tooth count... I'm a three-pedal guy.
77 should be 28oz balance. 351/5.8 always stayed with 28oz and didn't change like 302. Just get a flexplate from a pickup with AOD and 5.8. All AOD's had same ring gear count. 50oz weight will look about 2 times as big as the 28. Lots of reading on AOD swaps everywhere. Should be able to use same starter.
jeffinct
05-07-2018 09:17 AM
rugermack
01-24-2015 05:40 AM
Schmitty
17
09-12-2013 12:29 AM
Handegard
05-31-2010 09:07 PM
