Flaky steering wheel controls 2004 Navigator
Hi all,
One of the minor but fairly annoying traits I've noticed in our 2004 Navigator (Ultimate, without Navigation) is that the steering wheel controls seem to have a bit of a mind of their own.
For instance, sometimes the volume button will skip to the next cd track. Sometimes the temp button will adjust the fan, sometimes the mem button does a source change. Sometimes cruise control doesn't want to set etc.
Anyone have a similar issue and have any idea how to resolve?
Perhaps dirty contacts? These buttons work on varying resistance principle. I.e. when you press Fan up button, the circuit shows 300 ohms, but when you press Mem it will show 400 ohms, and so on. (values are only for example, not the actual values). So a dirty contact might present a different resistance, and be misinterpreted by the PCM or system.
Remove the buttons, and clean the contacts would be a good thing in this case. Depending on your skill level, perhaps verifying that the resistors have good contact and are in spec could be a step to take as well. The switches aren't cheap, so definitely worth to attempt to repair the ones you have.
vacuumbed
01-29-2016 06:06 AM
drakerc
06-13-2015 09:59 PM
TheMilkman00
06-23-2011 08:27 AM
jerzydiver
11-05-2006 10:34 PM
