Well I guess I will be installing a new water pump. ....
I came out of work to see a fair amount of fluid on the ground under my excursion (2000 limited 7.3l 4x4). So I checked my fluids and found the coolant low and all the other fluids were good,. I had some in the excursion (not sure why I had it but it was there ). Filled it as much as I could started the truck and there it was a pretty big leak from my water pump. I was able to get one (new one lifetime warranty from an auto parts place, Ford was closed) so now on my day off instead of relaxing I will be installing a water pump. I guess it was about time. I figured since I was there I might as well flush the system. Does anyone know off hand how many gallons of coolant this will take to refill the whole system? Thanks in advance.
Now is a good time to back-flush your system and upgrade to an OAT ELC. Check out my Gooch coolant flush how-to thread in the tech folder.
Stewart
I should have changed it but I didn't. Oh well next time I have to work on the excursion. I was up for 36 hours straight. I need sleep. .....lol
mike L
06-29-2006 04:54 PM
