Hood rattles when closing
It seems the adheasive between the structure of the hood and the top sheet metal has come undone and rattles when you close it. At one point it looks like the PO tried to tac weld it in a couple spots. Those have busted and caused some pin holes in the hood (probably during the welding).
What should i use use to fix this? Some kind of high heat adheasive?
on
Those areas may have a built up of greasy oil dust that would keep any form of epoxy sealer to re-bond the two back as one unit.
So the under areas would have to be pushed back into place and held for a time for the epoxy to dry/cure.
I've used some types of seem sealers that harden that may do the job
that I've found online an ordered.
May be Jeff or Bill can give you more info on using this epoxy.
Orich
Orich
Orich
Orich
*easy to use formula creates uniform bondline thickness every time despite differences in clamping technique.
*tough modifies acrylic formula.
*For bonding cold rolled steel, galvanized steel, aluminum and scuffed e-coat covered steel.
*Built in color indicator turns from beige to green when initial set has been achieved.
Bozworth
58
09-22-2016 04:52 PM
Jimmyrig
15
03-26-2013 08:12 AM
jlasater
12-12-2001 03:50 PM
