Well, it was my turn this week
Suspected there could have been a head gasket issue even a few months after I purchased 3.5 yrs ago. I made it another 60,000 miles before it was truly evident. Until the past few months I would on occasion lose a little coolant out of the degas cap on long towing trips that involved an extended pull up a grade. About a year ago I added to my scan gauge an EGT and coolant pressure gauge from Isspro. Keeping a close eye on the pressure it would hover around 14 but never peaked over 16. Last month when I moved by old backhoe the gaskets really gave out and it was the first time my gauge went to 20lbs. After that I couldnt even tow my empty trailer without it getting hot. I also noticed at the end of the summer my oil temp spread increasing from my normal 3-4 to 8-9 degrees and the inside of the degas bottle had some black deposit on it.
There is a very slight line around a short section of the #1 cylinder indicating a very bad spot in the gasket. Both sides had been blown out but only in this spot was it really bad. Still inside the fire ring to all should be OK. New Gaskets, studs and related parts going back in with a new oil cooler as well. Flushed it really well before it was torn down to clean it out.
Looking at the #1 cylinder, it would be at about the 10/11 o'clock position. You can just make out a line around the outside of the cylinder wall. On the gasket I would say the shiny area in the pic. I didn't take the pictures, just sent to me. This is too much of a project for me, and with the time involved, I might as well stay working rather than take off work to fix the truck.
Negative, I couldn't get a good feeling about any of the larger shops around me, dealer or large independents. So this is at a 1-2 man shop that does a lot of engine swaps and builds, ford/cummins swaps, 5r110 rebuilds ect.. Came by recommendation of a good friend of mine who went to Ford Tech school and works for a local bus company. I had asked him about 6 months ago if he wasn't going to work on his own 6.0 who would he let open the hood, and he sent me here.
Ditto,,, just spec'ed a block tonight that got cleaned like that,, bought from the Fayetteville area from a golf course owner. Had studs and the block was wiz wheeled. Yeah,, that block is getting disassembled and decked to fix it. It's not at my shop but they called me to check it out. Freakin shotty job for sure. Not saying yours is,, but the one I looked at today was trash.
Can't speak as to what he used to clean the block, but I do know he checked it to make sure it was in spec for square and flatness. I'm not one to over question a person's work, otherwise I wouldn't let them with on what I own. When I first met him he was working on heads for a different brand truck that is owned by the local town govt. So I was able to see some of his work prehand.
Until 2 weeks before I put the truck under the knife, the only time I would break 200 coolant temp was towing up hill( more pressure on the engine). Fan would bring the temps back down when it reached 207ish to kick the fan on. Rarely got over 215 oil or coolant but I didn't beat it either. My pressure gauge would show as yours, 14-16. I didn't break 16 till my last tow before there work was done, hit 20. And that was confirmation for me. The most popular place for the pressure sensor is in the return line at the Degas bottle. Upon inspecting the gaskets that were removed, they were bad a long time. You may want to reconsider. Have you lost coolant? Do you have an egr cooler?
