Replaced my lifters (one broken) - Intake popping solved
For the last couple of years when I would start my truck I would get a very loud popping noise in the intake. I mean loud enough that people would turn to look over at me. It was intermittent at first, but became more common as time went on. It was especially bad with fresh oil changes until eventually it was popping all the time when running hot or cold, albeit not as loud as when it first started up.
So I jumped on Rockauto, ordered a set of lifters and put them in. The problem lifter was on the passenger rear (#7?) exhaust valve. I couldn't get the pushrods out on that cylinder to check them because of the evaporator case and didn't feel like fooling with it. The problem is fixed except for the faintest little noise until oil pressure pumps up the lifters, so it may have bent that pushrod slightly.
Speaking of pushrods, keep them oriented by cylinder and which end is up/down along with keeping the rockers in the same position as well. Some of the faces the work the valves were a little worn looking but the truck has 233k on it.
Job took me about six hours taking my time, being tedious and very clean. I had to run to the store for RTV and a new fuel pump. I noticed a crack in the top of the pump and it was leaking diesel down all over the underside of the truck. Do yourself a favor and use compressed air to blow all the dirt and debris from the valley pan too. I replaced mine but probably could have reused the old one. I had to cut it apart to get the CDR stand pipe out of it because it was so hardened at the bottom. CDR end was still pliable.
normalmike
11-06-2013 11:48 PM
robcblair
08-07-2013 08:26 AM
twtcad
13
07-28-2011 08:47 AM
jk_hooper
02-19-2010 10:34 PM
73GreenF250
08-29-2004 11:02 AM
