headliner adhesive
For heavy fabrics I've used epoxy resin thinly brushed on with great results. Never a sag nor under extreme heat has the fabric, leather, rubber, whatever etc separated from the resin. Great for recovering dash boards where the sun hits it all the time. JoAnns should have some in their crafting sections.....wait, JoAnns is a craft store.
DOH!!
DOH!!
The problem with PVC is that it has a low surface energy and nearly nothing bonds to it. The usual way to bond PVC involves fusion, either with heat or a solvent based glue.
You may have some luck with a specialty adhesive such as 3M 1099.
I don't know anything other than what 3M says about this adhesive or even if it's available to the general public but it's the kind of adhesive you need to be looking for.
You may get a better bond by lightly sanding the PVC to give it some tooth but I've never has success with gluing it without a solvent based glue and solvents will destroy the Naugahyde. You might also test Fusion brand spray paint as an interface between the PVC and a water based adhesive such as Weldwood water based contact cement. I've no idea if it will actually work but it's worth a try.
Romel77
05-03-2015 11:32 PM
Ford4Life7.3
10-11-2011 01:42 AM
