Accelerator Pedal
Old 10-26-2016, 11:27 AM
WhatsAChevy?'s Avatar
WhatsAChevy?
WhatsAChevy? is offline
Question Accelerator Pedal
Hey Folks, Where the accel pedal pad fits onto the pin at the bottom of the arm, the pedal is flopping off on the right side (towards trans tunnel). The right side of the pin is smooth (no groove) so an E clip won't work. I'm wondering if there was a flat push-on friction type retainer used to prevent the pad from shifting left to right. I've searched quite a few illustrations but no mention of it or a replacement pad.
I'm thinking similar to this.
Old 10-26-2016, 12:16 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Ford did not furnish the pedal pad or the spring behind it...by themselves. These parts were only available with the accelerator assy (shown as 9725 in pic).
On 1979 and earlier, these parts were available separately. When the spring broke, the pedal flopped around.
F2TZ-9725-D (replaced EOTZ-9725-A & E7TZ-9725-A) .. Accelerator Assy / Obsolete
1980/96 F100/350 & Bronco / 1997 F250 H/D & F350.
No Ford dealer or obsolete parts vendor has any.
E7TZ-9725-A =
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
EOTZ-9725-A =
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 11 = 607-722-5371.
Old 10-26-2016, 02:21 PM
WhatsAChevy?
I appreciate the response Bill. I'll try a friction retainer . Turns out I'm going to need an accelerator cable also as it broke at the plastic flange at the engine bracket about 40 minutes ago on the way home from the store. I rigged it to hold to get it home. Rock Auto shows one : ATP Y284 Alternate/OEM Part Number(s): E0TZ9A758B, E1TZ9A758B, E1TZ9A758E, E4TZ9A75eightD
Old 10-26-2016, 08:05 PM
NumberDummy
Originally Posted by WhatsAChevy?
I appreciate the response Bill. I'll try a friction retainer . Turns out I'm going to need an accelerator cable also as it broke at the plastic flange at the engine bracket about 40 minutes ago on the way home from the store. I rigged it to hold to get it home. Rock Auto shows one : ATP Y284 Alternate/OEM Part Number(s): E0TZ9A758B (20 7/8" long = 1980 only), E1TZ9A758B (1981 only-21 1/2" long), E1TZ9A758E, E4TZ9A758D (22 1/2" long = 1984/85 351W 4V & 1986/87 F250/350 460).
The only cable that's correct for your application (1984 F150 302) is E1TZ-9A758-E = 19 3/4" long.
Since Rock Auto is showing multiple OEM part numbers that have various lengths and applications for their ATP Y284 cable, it's probably a "universal fitz-all."
Old 10-27-2016, 10:06 AM
WhatsAChevy?
You would be correct sir. I searched those OE numbers and they all pointed to the aftermarket 23" cable from numerous brands/distributors. Worst case, i'll take up the 3.25" excess with a slight radius under the hood or...cut the ball off of the pedal end and take up slack with a cable clamp, or both. Let's hope there's no sheathing mods required.
Old 10-27-2016, 08:44 PM
Rusty Bucket Ohio's Avatar
Rusty Bucket Ohio
Rusty Bucket Ohio is offline
I Had that same thing happen to my 86 with the 300 ... got a cable from Napa for the 302 which was too long but I put a spacer between the ball end and pedal stop ... works like a charm ... might check Napa
Old 10-27-2016, 09:06 PM
WhatsAChevy?
I have considered using a spacer. It is supposed to arrive tomorrow. We shall see...
Old 10-27-2016, 09:15 PM
Rusty Bucket Ohio
...on mine the plastic broke between the bracket and carb ... all it wanted to do was fold up and jam ... need the whole plastic there to keep it straight ... being a little long worked ok but didn't let the throttle open up all the way so the spacer did the trick ...
Old 10-28-2016, 11:44 AM
WhatsAChevy?
What did you use for a spacer ? I'd rather not cut the end off the cable if there's a better option.
Old 10-28-2016, 12:00 PM
bcamill's Avatar
bcamill
bcamill is offline
Jumping in here. I have used a zip tie for a spacer and it has been fine. Just cut off the excess. Add two if needed.
Old 10-28-2016, 12:09 PM
WhatsAChevy?
Funny you should mention that. I was just over at YouTube and saw that.
Old 10-28-2016, 02:53 PM
Rusty Bucket Ohio
If You are a fisherman ... Split Shot
Old 10-28-2016, 05:00 PM
WhatsAChevy?
Not much of a fisherman but I do know what it is....good idea.
Old 10-28-2016, 05:15 PM
WhatsAChevy?
Smile Finished...Thanks Everyone
So the new cable came this morning and it was a breeze to install. Throttle response is like a new truck with full range now. I ended up using a cable clamp to take up the difference at the pedal arm. After searching in my hardware cabinets, I came across a few flat push on retainers and actually found one that fit the pedal pin ! whoop whoop ! Tight throttle and no more floppy pedal.
Mark8man
03-19-2019 08:11 PM
maddogjohnson
01-04-2018 03:40 PM
dmanlyr
Large Truck
05-11-2017 05:16 PM
gdoakes
Large Truck
05-01-2017 06:06 PM
dents&more
1978 - 1996 Big Bronco
11-07-2009 01:36 AM
Quick Reply: Accelerator Pedal
