Thought you guys would like this.....
A local fire apparatus builder/dealer is building their first B.R.A.T. with a 2017 F550. I figured I'd post some pics for you guys to see. Here are the specs of what will be built:
2017 Ford F550 Four Door Crew Cab 4x4
SCBA Cab Seats
6.7 Liter 300 HP Diesel Engine
Aluminum Bonded Body with ROM Roll up Doors
Hale 30FS 300 GPM Pump / Deutz 60 HP Engine Combo
All Akron Brass Valves
Pump and Roll Capability
Pro Poly 300 Gallon Water Tank
One 1.5" Rear Preconnect, 2.5" Direct Rear Discharge
Firematic Extended Front Bumper
Extended Console in Cab
Stokes Basket and Ladder Mounted Top of Body
Whelen LED Lighting Package
FRC Telescopic LED Scene Lighting
I will update with more pics as the build progresses!
SCBA Cab Seats
A couple of years ago a small rubbish burn worked into a huge field and swamp fire which first one, then another and another up to 12 locals fire departments responded with their "BRAT'S" as I now know the name of them. Some very elaborate, some very heavy and all mostly parade vehicles. The shiny big tire'd rigs attacked the fields and swamps until every one of them was sunk, many up past the rocker panels, and yet the fire burned on, all the way to the railroad tracks where it self extinguished. It was quite a sight to behold. Tractors and bulldozers, wreckers and mudders. The local mud boggers could not have organized a more entertaining event.
Also if it does get that hot...the gas tank will light off long before that happens. You are screwed regardless if it is steel or aluminum.
I can't wait to see the build progress! Thanks for posting this and look forward to seeing how it all turns out!
Thanks to you for your commitment and service in the Fire Service! Where in California are you located?
At that point you get under the blanket and kiss your butt goodbye because you're about to leave the fire scene at 10,000 feet per second.
OP, great post Buddy! keep the pictures coming if you get anymore.
