93 Bronco Cam question
I was wondering if a cam for a 351w can be put in the 302w in a Ford truck engine I am trying to make my bronco wake up a bit and I heard of a 351w cam going into a 302w will wake that engine up like crazy..... So who has done this and is there any issues to watch for?
on
If the motor in your '93 is original it has a roller cam in it while most 5.8 motors of this vintage and older had flat tappet cams, so swapping one of those in would be a step backwords. But the stock cam in your motor is very small so you would benefit from an upgrade but I wouldn't suggest installing another stock cam because they're all really tame.. buy something aftermarket like the Comp 35-512-8
ok tranny is built to the point it is unbreakable I ran it dry on the highway once old owner did nothing but build the tranny it has 33" tires and JBA shorty headers all I Wana achieve is when I stomp it I Wana break the tires loose from a dead stop axle has 355 gears open rear end planning on putting in a posi trac kit where u just replace the spyder gears
but it's 4x4 changing the gearing in the rear would require it to be done in the front also or the transfer case will fail
