What are you using for shifter boots?
Hurst shift arm on my TKO... 70 Hurst boot and trim ring.
I've made one using vinyl, a hose clamp on top, and a bottom frame bent from a coat hanger... the boot is folded inside out and the upper neck clamped on the arm. Then the boot is pushed down... gives it a nicely dressed edge. Then the bottom of the boot clamped under the trim ring. Try it... you can sew, right???
