6.7 real mpg's please
At risk of being called a liar again, my friend has a 2015 6.7 and back in August we got an actual 21 mpg on a 400 mile fishing trip with full camping gear and an 18' boat in tow. These engines get better as time goes by and everything gets fully seated and the computers learn their mission. A light foot helps tremendously however, there is a lot of weight to get rolling and some of us have pretty heavy right feet
on
it was a concern when I first bought it but is did come up
in fuel mileage.
one thing that helps you to speed things along I found.
espicially after towing.
Remember like a kid the truck is always learning
your habits.
So a reset on fuel gadge.
i always reset going down hill & never too heavy of a foot.
goes a long way.
Helps reset from heavy trailer pulls quickly.
Do you guys up north use US gallons or Imperial (British) gallons? I know when I was in England for a while a few years ago, that the Brits buy all of their fuel in liters (as you do in Canada) but whenever you ask an Englishman about fuel economy, they stubbornly recite imperial MPG figures.
US gallon = 3.785 Liters
Imperial gallon = 4.546 liters
Using these figures, 21 imperial MPG is equivalent to 17.5 Murican MPG.
I have to chuckle a little every time I see these "what should I expect for mileage" threads.
While the weight of a vehicle does matter when it comes to overall mileage, it's pretty negligible compared to the speed that the vehicle is driven due to wind resistance. For example, at 50 mph it takes 8 times more hp to drive that same vehicle at 100 mph. That's why it takes between 600-700 hp for a sedan to break 200 mph. Below are some words for a study that was conducted.
According to studies backed by the department of energy, the average car will be at its advertised MPG at 55 mph. But as the speed increases:
- 3% less efficient at 60 mph
- 8% less efficient at 65 mph
- 17% less efficient at 70 mph
- 23% less efficient at 75 mph
- 28% less efficient at 80 mph
The SD is a slightly aerodynamic brick (a good looking one I might add) and mileage will vary depending on whether it is 2wd or a 4x4, mirrors extended or not, etc. No two people drive the same speed and one guys 65 mph is far different than the guy cruising down I-15 in Utah at 85 mph. Let's not forget city vs. hwy, tire size and gearing, headwinds or not, and the frontal area of anything being towed. I'd bet I could 25 mpg out of SD, so long as I was happy driving it at 45 mph.
I think it's safe to say you'll get anywhere between 9 and 21 mpg depending on how you drive it and cross section of the configured vehicle.
Adam
Adam
