lincoln 337 few questions
Hi every one im looking for help everywhere i can . Maybe somebody can aswer me on few question.
1 wich care came from this set ( engine and transmission) cosmopolitan?? because i want buy some service manual ( i cant remove cam shaft, which is snaped on 3 pieces)
2 i need few parts can some body recomended me shops online where can i get it ( cam shaft, piston rings, gaskets, fuel pump, crankshaft berings)
3 what is the best way ignition converion ?? ( 12v alternator)
Easy questions- there are fuel pumps Expensive on ebay (i need one too so I run
electric pump) gaskets are also on ebay. Kanter in NJ most likely can help with
bearings etc. one wire alternator, new 12vt coil and resister (your 6vt starter will
work fine with 12vts)..
Hard question; broken camshaft >how in the world< did that happen?
Next does it have hydraulic lifters? because I don't know if a solid lifter cam will
work I'll check on that. Or Chucks Trucks LLC he's a member here....does this
help a little. sam
help a little. sam
Thans for reply !!
Maybe you know which car that set come from, because i dont know wich service manual i needed. ( for bolt torque, wire diagram etc.)
I thing sombody tryed start up the engine after long time when valves not moving that why snaped. because nothing more damaged. lifters looks perfect but 3 of them i found in sump :
Kanter is some guy ?? or some parts shop ??
por 12v conversion i need new aleternator or can i use my gnerator 6v for conversion too ??
What about ignitio system?? can i bou some set ( dustributor, coil, module exactly for my engine ??
Kanter Products: https://www.kanter.com/
Your engine has an automatic trans, so it is clearly a Car setup, not from a truck. There are differences between Car and Truck 337's. Honestly, your best bet is likely to be on the Ford Barn, Early V8 (1932-53) - The Ford Barn
You should mention you are in Great Britain, there are members over there who may be able to help. That engine/trans are difficult to find some parts for, more so over there I suspect.
Thans for reply !!
Kanter is some guy? Or some parts shop?
But it wasn't too long after, when they began selling all makes of parts, because there were just so many NOS Packard parts to go around.
Not sure value but I've seen 2 of these come up in the last week. Other one seems to have sold for almost $1000 more but was total rebuild.
https://corvallis.craigslist.org/pts/5807199675.html
a 8EQ and I have no clue if it is compatible with hydraulic lifters or not.
I do know some trucks had hydruaulics. There is no mention in the books
It shows only part numbers on both lifters and a part number on the cam.
I'll take a pic today for you.
sam or email me at Visicoach@comcast.net.
Autumn
10-21-2016 03:37 PM
bobby738998
05-18-2009 10:38 AM
