C6 Transmission Filter question...
I dropped my transmission pan on my 4x4 c6 to put a new gasket on, and the kit comes with a filter. So i swapped out the filter, replaced the filter gasket with a metal one that apparently doesnt require any sealer... And then bolt it all back up. What i didnt realize is that I hadnt pulled out the small tube from the old filter and put it into the rubber grommet on the new one. Im assuming its for sucking the fluid from the bottom of the pan into the filter?
My question is... Do I need to pull the pan off and scrape all 'the right stuff' gasket maker off, and buy a new gasket so i can put that 1 1/2" tube in?
Yes drop the pan and install the tube!! Also make sure to clean sealer off all surfaces and straighten out pan flange (where bolts go) , make sure none of the sealer got sucked up into the filter, this is bad because you can starve front pump of oil and cause trans failure !!!! Be sure to use gasket and NO SEALANT of any kind.
cabloom300
11-03-2013 09:52 PM
Corpsman24
08-19-2013 10:18 AM
kyle j
09-04-2011 09:37 PM
